Uploads by Phil Short
File list
Date Name Thumbnail Size Description Versions
19:22, 6 June 2013 Renard-px1 RevE.PNG (file) 33 KB   1
16:16, 6 June 2013 Renard-px1 RevE sch.PNG (file) 33 KB   1
18:08, 2 November 2011 LEDancer-20111101.asm (file) 18 KB   1
18:02, 2 November 2011 LEDancer-revA.png (file) 18 KB   1
17:53, 2 November 2011 LEDancer2.PNG (file) 35 KB   1
19:28, 27 May 2011 LEDancer1.png (file) 33 KB   1
19:13, 27 May 2011 LEDancer PCB Example1.png (file) 13 KB   1
18:22, 27 May 2011 Ledancer-20110527.asm (file) 17 KB   2
18:19, 27 May 2011 LEDancer-20110527.asm (file) 17 KB   1
15:33, 22 May 2011 LEDancer-20110522.asm (file) 15 KB   1
15:14, 22 May 2011 LEDancer-20110521.asm (file) 15 KB   1
05:02, 22 May 2011 LEDancer LED SCH.png (file) 25 KB   1
04:59, 22 May 2011 LEDancer LED SCH.PNG (file) 25 KB   1
04:49, 22 May 2011 LEDancer.PNG (file) 33 KB   2
04:34, 22 May 2011 LEDancer PCB Example.png (file) 13 KB   2
04:15, 22 May 2011 LEDancer LED Module.PNG (file) 8 KB   1
04:08, 22 May 2011 LEDancer.png (file) 32 KB   1
21:20, 9 January 2008 Renard64 xc.pdf (file) 103 KB XC rev schematic, as the board went out for proto. Schematic manually created after the fact, so take it with a grain of salt. 1
21:18, 9 January 2008 Renard64 xc5b.gif (file) 48 KB PCB as it went out for proto. 1
21:07, 8 December 2007 Grinch pcb assembled.jpg (file) 67 KB   1
01:26, 24 October 2007 Renard-20071023.asm (file) 17 KB Beta test code...changes in attempt to reduce flickering at low dimmer levels with LED strings. 1
04:03, 12 October 2007 Renard64 sch 002.pdf (file) 105 KB   2
03:24, 31 August 2007 Ren-diag-20060905.asm (file) 8 KB   1
00:19, 29 August 2007 Renard64 layout XB.gif (file) 42 KB   1
23:54, 18 August 2007 Ren-diag-20070815a.asm (file) 8 KB Renard diagnostics firmware - uses external 18.432 MHz oscillator 1
21:19, 17 August 2007 Xformer ct.gif (file) 3 KB Revised Drawing - center-tapped transformer with rectifier 1
21:07, 17 August 2007 Xformer conn2.gif (file) 53 KB Transformer Connections using a center-tapped transformer 1
21:07, 17 August 2007 Xformer conn1.gif (file) 53 KB Connections when using regular transformer 1
20:37, 17 August 2007 Sinewave rect.gif (file) 725 bytes Unlabelled rectified sine waveform (abs(sin(wt)) 1
20:36, 17 August 2007 Sinewave nolabel.gif (file) 733 bytes Unlabelled Sine Waveform 1
20:26, 17 August 2007 Xformer ct.GIF (file) 3 KB Schematic of a center-tapped schematic with a two-diode full-wave rectifier 1
20:25, 17 August 2007 Xformer regular.GIF (file) 3 KB Schematic of a simple transformer with a full-wave bridge rectifier 1
17:28, 30 June 2007 Renard64 sch 001.pdf (file) 105 KB Schematic for Renard64 - document the board as it is now. 1
03:18, 30 June 2007 Transformer pcb sch 002.GIF (file) 9 KB   2
15:45, 29 June 2007 Renard8-20070228b.gif (file) 24 KB Screen capture of PCB layout. 1
15:42, 29 June 2007 Renard8 XA sch a.GIF (file) 21 KB Updated schematic for first Rev PCB 1
15:20, 29 June 2007 Renard8 XA sch.GIF (file) 19 KB Schematic for first revision of Renard8 PCB 1
18:30, 28 June 2007 Transformer pcb sch 001.GIF (file) 20 KB One possible PC-Renard Interface, using RS232. Pinout is for Xmus Board, Renard64, Ren-C and future Renard8. 1
23:43, 23 June 2007 Dimmer waveforms 001.gif (file) 2 KB Some dimmer waveforms, needs editing to add labels 1
20:27, 23 June 2007 Renard8 img 001.jpg (file) 17 KB Somewhat poor image of an assembled renard8 pcb. 1
16:40, 23 June 2007 Renard generic sch.gif (file) 11 KB Generic Renard schematic, identical to the one currently on the cc.com how-to. 1
