The 5.030-01 update is only for the 680 and 681. The 6804 and 682 are still at 5.030.
Sent from my SM-T710 using Tapatalk
Not according to the first page of this thread. Says E682 uses version 5.030-01
You're correct. I misread it. I have 5.030-01 installed but the controller web page still says 5.030.Not according to the first page of this thread. Says E682 uses version 5.030-01
I love the 682 but would like to see a couple of changes. First the outputs. When using Renard you have to set the jumpers for balanced outputs which works for a bank of 4 outputs. I use 1 output for Renard and the other 3 outputs are wasted. On another controller, 2 are for Renard and 2 are wasted. The other thing would be LED fuse indicators. Another possible change would be adding an ethernet port for daisy chaining. I would guess any of the above changes would require a complete redesign and making the board larger but I thought I would just mention them.
I agree with you on the changes.
Does anybody know where this going? Is a new design in the works?
It has been nearly 2 years sense this firmware thread started and I'm just wondering what's up
with this project. Is this it or is there more coming.
E682 is a great board but some improvements would be nice.
If you are using three outputs, why not put them on the same controller and free up 4 banks on the other controller. If you are running a computer or FPP, you could always use a USB/RS485 to get to the first Renard and then daisy chain the others.I love the 682 but would like to see a couple of changes. First the outputs. When using Renard you have to set the jumpers for balanced outputs which works for a bank of 4 outputs. I use 1 output for Renard and the other 3 outputs are wasted. On another controller, 2 are for Renard and 2 are wasted. The other thing would be LED fuse indicators. Another possible change would be adding an ethernet port for daisy chaining. I would guess any of the above changes would require a complete redesign and making the board larger but I thought I would just mention them.
I moved away from daisy chaining Renards. When there's trouble with one, especially at the beginning of the chain, it affects all the others. There's about 150 feet between props on each side of the property so I find it more convenient to assign one output of each 682 or 6804 to Renard. That way, if something does happen, the whole Renard controlled part of the display doesn't go down.If you are using three outputs, why not put them on the same controller and free up 4 banks on the other controller. If you are running a computer or FPP, you could always use a USB/RS485 to get to the first Renard and then daisy chain the others.
I do the same thing for my GECE's and just run a data wire and inject the 5 volts (tying grounds together). That way I only waste 3 ports. The current software version is so much "handier" than it was before (we lost the whole bank).
After reading about it I am curious to hear if Jim plans to update again to do the allowment of 1 universe per output ?
Sent from my SM-G930P using Tapatalk
I believe he means that you have 12 visible universe windows but 16 outputs. So if you want one universe per output the last four are not useable.
k6ccc is that in the first post and i must have over looked it??
jim hasn't logged in here since june. is san devices going to continue? i hope so mainly because i like building my stuff myself, but i'm concerned. why is v5 firmware still only in an "info" thread after 2 years?
