Search results
- =Sequencing Channels and Adding Effects= ==Creating Basic Effects== ...624 bytes (74 words) - 03:25, 25 March 2013
- ====[[RGB Channels]] {{:hls_ver}}==== ===<span style="color:blue">Sequencing Channels and Adding Effects</span>=== ...3 KB (368 words) - 02:37, 12 March 2013
- ...se would generally be used with RGB strings and display items, both "dumb" RGB and Pixels. However, they can also be used to reduce channel counts of "me ====RGB Channels in the Sequence Window==== ...3 KB (468 words) - 04:12, 24 March 2013
- ...ccess to several common sequencing actions and is particularly useful with RGB channels. To display the HLS Toolbar, Right-click in the sequencing grid and select ''Display HLS Toolbar''. ...3 KB (453 words) - 19:28, 25 February 2013
- ==RGB Channels== {{:RGB Channels}} ...3 KB (410 words) - 17:36, 24 March 2013
- To quickly get up and running with a sequence, you may want to look at the '''[[HLS Getting Started Manual]]'' ...at follow will contain, in parenthesis, information that can help the user with a quick visual inspection: ...4 KB (562 words) - 00:52, 26 October 2013
- ====Introduction to Custom Effects==== ...first step is to create an effect template from defining an order of basic effects. Then, that template is applied to a selection box in a number of configur ...5 KB (822 words) - 00:39, 26 October 2013
- *Ramp Up an eight channel chase over five seconds so that the chase builds with the music rather than being 100% on. *Ramp down at the end of a sequence to fade out running effects as the music fades. ...3 KB (539 words) - 04:11, 24 March 2013
- ====Introduction to Sequencing in HLS==== ...s to lighting channels at specific time intervals to coordinate the lights with a set peice of music. HLS is different than other sequencers in that it mo ...7 KB (1,203 words) - 00:38, 26 October 2013
- ...to treat a large amount of channels as if they are one. Anyone sequencing with lots of pixels, using external programs like nutcracker, or looking for add *When done with Universe assignment, click ''Renumber Channels for Output'' to complete the ...7 KB (1,045 words) - 04:15, 24 March 2013
- ...to treat a large amount of channels as if they are one. Anyone sequencing with lots of pixels, using external programs like nutcracker, or looking for add *When done with Universe assignment, click ''Renumber Channels for Output'' to complete the ...7 KB (1,045 words) - 04:27, 12 March 2013
- ...rk with your pixels. Many Pixel Controllers use E.131 ethernet connection with the computer. [[E1.31_(Streaming-ACN)_Protocol|Click here for more info on ...'' - most strings are 5v but there are some 12v. Each pixel will use 60ma with full on white. So Each 50 pixels will use 3 amp. It is best to get one th ...4 KB (603 words) - 18:08, 5 August 2013
- ...in more than one Display Group. Groups make it possible to show and work with a subset of the channels. ...Groups DISPLAY channels in the sequencing window. Preview Groups are used with the PREVIEW window to help visualize how channels will be physically repres ...5 KB (753 words) - 01:02, 24 March 2013
- [http://www.nutcracker123.com/nutcracker/ Nutcracker] is a web based RGB Sequence builder designed and built by [http://doityourselfchristmas.com/fo to create sequences on target RGB objects. ...25 KB (4,358 words) - 15:54, 15 August 2014
- ...ng Started Manual updated reflecting the current version of the software. With the speed that Joe continues to add new functions and power to HLS, the man The HLS forum on DIYC is filled with excellent information on how to operate the software and what to watch out ...9 KB (1,466 words) - 05:48, 20 October 2013
- ...'. What happens, happens. If you save your sequence right before working with channels, if something goes wrong, you can always restore to the previous b *'''RGB:''' This checkbox is checked when a channel is an RGB lighting element or pixel. ...13 KB (2,084 words) - 04:26, 20 October 2013
- *'''Ensure that channels are properly added to the sequence, rgb channels are identified, and colors are setup in the Channel Manager.''' ...her into one ''Preview Object''. For example, an arch can have 8 segments with each segment assigned to ''Preview Group 3''. ...18 KB (2,920 words) - 04:12, 25 March 2013
- ...''B'''lue. A string of 50 Pixels would use 150 channels in your [[Software|sequencing software]]. ...ngs should never be strung using their wire to support them like you would with regular light stings. This will damage the Pixels and their waterproofing. ...51 KB (7,006 words) - 18:57, 4 June 2022
- There are many different types of controllers used for RGB lighting effects. The most common fall into two different categories: *Dumb RGB Controllers.<br> ...36 KB (4,823 words) - 19:19, 4 June 2022
