Beginners Guide To Programming A PIC
Here you will find guides on how to perform basic programming of a PIC.
How to guides and videos
File:How to program a PIC.pdf: Please note that this guide uses a PICKit2, The most common PIC programmer among DIYC members, but the process should be very similar for other PIC's and programmers.
File:PICKit III.pdf: Guide for using a PICKit III to program a PIC using a "HEX" file. The first few screens would be the same for the "ASM" file but then you should be able to use Waynes videos for the "project creation". You should also be able to use this for the diagnostic firmware, just change the file name that you select in the file browser. Made by Mmulvenna
WayneJ's video series on PIC programming: For those that prefer to see it done in a video.
Microchip PIC References: Other information and tutorials on PICs.
PIC Programming Hints: Hints to programming PICs.
Gooligum PIC Programming tutorial series
Where to buy Programmers
Depending on the controller design you will either need just a programmer like the Pickit2 or you will also need a ZIF socket to program the PIC. If the controller has an ICSP header then you do not need a ZIF socket, but it is a good idea to purchase one.
Pickit2 and 14pin ZIF socket from DIYC user J1sys
Pickit2 clone with built in ZIF socket from DIYC user tjetzer
Pickit2 clone with ZIF socket from EBay
Zif socket only Useful if you want to buy the socket later and for multiple sizes.
