Renard SS8 Controller Board
Contents
- 1 Introduction
- 2 Disclaimers
- 3 The Board
- 4 Circuit Diagram
- 5 Firmware
- 6 Powering the Renard SS8
- 7 AC Power Handling Capability
- 8 Hooking Up the Renard SS8
- 9 Configuring the jumpers on Renard SS boards
- 10 Computer Setup
- 11 Assembly Instructions & BOM
- 12 Setup for Beginners and Troubleshooting
- 13 Related Links
- The Renard SS8 is a PIC microcontroller based Christmas light controller with 8 solid state relay circuits incorporated into the board. The board design is based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed here. Generic information pertaining to current Renard designs (including maximum channel count) can be found on the Renard wiki page.
The Board
Board Availability
Circuit Diagram
- Key circuit components
- Connectors
- J1 – RS485 outgoing data
- Connectors
- IC Chips
- U6 – PIC16F688 Microcontroller
- M1-M8 – MOC3023 Optoisolator, triggers the triac
- IC Chips
- Resistors
- R18-25 – Triac gate resistors. The value of these resistors in the BOM was selected for locations using 115/120 VAC power.
- Resistors
- Diagnostic LEDs
- Diagnostic LEDs
- Other Components
- T1-T8 – BTA06-600CW
- Other Components
- Jumpers
- JP2 – 120 ohm termination resistor enable. Normally a shunt will be installed on JP2 when receiving RS485 data. Remove the shunt if you are experiencing problems with incoming data.
- Jumpers
- Test Points
- GND – Ground
- ZC – Zero Cross signal
- Test Points
- The PIC (U6) must be programmed with the correct firmware for the board to operate correctly. There are two types of firmware available: Operational and Diagnostic. The Operational firmware is what you need for normal board operation. The Diagnostic firmware is a troubleshooting aid to use when there are problems with the board.
- Renard SS Operational Firmware:
- Renard SS Operational Firmware.asm – source code that needs to be compiled
- Renard SS Diagnostic Firmware:
- Renard SS Diagnostic Firmware.asm – source code that needs to be compiled
- DMX Firmware:
- Since there are many options available with the Renard DMX firmware it is impractical to post a dedicated Renard SS board version here. Users desiring to use DMX should get the firmware here.
DC power:
- The Renard SS8 generates all the DC voltage that it requires on-board and no external DC voltage source is required.
AC Power:
- The Renard SS8 requires AC power for generation of the DC voltage, the SSR (opto/triac) circuitry and for generation of the Zero Cross signal. The information in this wiki is targeted at users who are using 115/120 VAC power.
Maximum Input Load
- The Renard SS8 has one bank of eight triacs. This bank of triacs is capable of carrying up to 15 amps of current based on the trace width used on the pcb.
Triac Loads
- Based on the pcb trace widths, each triac can handle up to two amps of current. A heat sink is highly recommended when running the triacs at two amps. Care must be taken to ensure that the total load of the eight triacs does not exceed the rating of the fuse protecting the triac bank or 15 amps (whichever is less).
- The bank of triacs is protected by a fuse. The size of the fuse cannot exceed the current handling capability of the input wire or 15 amps (whichever is less).
- The BOM calls for a 10 amp fuse under that assumption that the Renard SS8 will be powered by a common/generic extension cord. Most of the common extension cords used by DIYC members are rated for only 13 amps and 13 amp fuses are not commonly found.
Data Connections
Data Cables
Cable Lengths
AC Power Connection
- The size of the fuse cannot exceed the current handling capability of the orange/black wires or 15 amps (whichever is less).
- JP1 & JP2 Configuraton
- JP1 installed
- JP2 not installed
- JP1 not installed
- JP3 Configuraton
Computer Setup
- VIXEN Settings
- Protocol Version: 1
- Parity: None
- Data bits: 8
- Stop bits: One
The assembly instructions and complete BOM with links to the Mouser Shared BOM
Assembly Instructions The Renard SS8
- If you are unsure that you have built your hardware correctly, you should follow the procedures contained in the Renard SS8 Beginners Setup Guide. These procedures will guide you through the steps to help setup the hardware for the first time.
- If you encounter any problems with your Renard SS8, you can go to the Troubleshooting Guide The Renard SS8. The troubleshooting guide contains a methodical process to try to isolate problems/malfunctions and gives suggestions of what to do to fix them.
