Electronics Hardware
Revision as of 17:51, 5 August 2013 by Jklingert (talk | contribs) (Firegod)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
  • Documentation: Firegod
This is a modular system that supports 32 to 128 channels per serial port, in increments of 32 channels, with 100 levels of dimming (using pulse width modulation - PWM). It consists of a host controller module and one to four field modules. The SSRs are not included on these boards, and must be provided separately. The interface to this system is RS-232. This system is no longer available on a coop basis. You would need to etch your own of find someone whp has one for sale. This board is intermediate in complexity to build.
Renard
Lynx
Helix
  • Documentation: Helix
LedTriks
Triks-C
LEDTRIKS LED PANELS
  • Connected to LEDTRIKS Controller: via CAT5 cables.
  • Documentation: LEDTRIKS Panel
PIX-C
  • Documentation: PIX-C
JEC Pixel Displays
  • Controlled through: DMX
rgbLED
Color Stick
RS485 Splitter
FM Transmitters & Antennas
DMX Boards, both converters and light controllers
This section is under construction, please consider all links broken below
Digital Input/Output Cards
