Search results
- ====Files Needed for Sharing/Moving Sequences==== ...omputer that you did the sequence work on, but needed to move sequences to a "show" computer for the actual output. ...2 KB (315 words) - 04:48, 24 March 2013
- ...omatically checks for the most recent version. If there is a new version, a window will open asking if you want to upgrade. If you choose yes, you will Due to the high rate of development of HLS, if a user is not monitoring the updates frequently, it is easy to fall several v ...2 KB (282 words) - 00:33, 26 October 2013
- *'''Tip:''' One way to organize the downloaded versions is to create a folder named "HLS Versions" and save downloads there.<br /> *Unzip the HLS_Install_**.zip and four files will be created in a folder named the same as the zip file. These four files are:<br /> ...2 KB (397 words) - 00:16, 26 October 2013
- ...http://doityourselfchristmas.com/wiki/index.php?title=HLS Back to HLS Main Page]]''' This User Manual and Reference Guide is a detailed guide to using all aspects of HLS. It is currently under signific ...4 KB (562 words) - 00:52, 26 October 2013
- ...Chases can be created manually in HLS, or, through an Action menu to chase a group (the easy way). ...channels. This can be level, ramp up, ramp down, or any other effect for a single channel. (See Figure 5-14 for an example where Ramp Up was chosen to ...3 KB (470 words) - 04:10, 24 March 2013
- ..., Nutcracker 3.0 was released, which moved from a web-based application to a software-based version in conjunction with [[xLights]]. The use of nutcrac ====Dropping a Nutcracker Effect Onto a PixelPlane==== ...5 KB (808 words) - 04:39, 24 March 2013
- ...lighting channels at specific time intervals to coordinate the lights with a set peice of music. HLS is different than other sequencers in that it move ...can be as simple as drag and drop without having to think about things on a channel level. ...7 KB (1,203 words) - 00:38, 26 October 2013
- '''Important:''' If you plan to use a time resolution that is different than the default (50 msec), it MUST be se ...ge and then click on '''Manage Raw Channels'''. At this point you will see a message reminding you to choose your time period resolution before you cont ...5 KB (899 words) - 00:00, 26 October 2013
- ...ttention to how I synch the lights. The following will help everyone from a their first year display to an experienced synch'er. Read below and I assu -I listen to a song well over 100 times before ever entering a sequence<br> ...6 KB (1,055 words) - 02:00, 29 January 2011
- ...this will reduce some of your confusion and get you on your way to having a computerized display. ...s consisting of light strings and other decorations. It often consists of a "light show" in which visitors to your display can view lights blinking and ...5 KB (913 words) - 00:44, 29 January 2011
- ...This page does not address (directly) the additional factors required for a lighting display, e.g., SSRs, extension cords, CAT5 cable, board enclosures This page is intended to provide a new member with a logical sequence of things that they need to consider when deciding which l ...9 KB (1,312 words) - 21:16, 28 November 2013
- ...standard disclaimers pertaining to the information contained on this wiki page are listed [[Disclaimers | here.]]<br/> ...sated constant current LED drivers allows the floodlight to operate across a wide range of temperatures and voltages. ...15 KB (2,589 words) - 02:28, 21 May 2015
- ...o apply effects to various PixelPlane objects. First, you must [[Creating a PixelPlane | create the PixelPlane]] before adding these effects. Figure 6-9 is the layout of the PixelPlane Editor when editing a MegaTree pixel object. Description of the highlighted areas and what they ...12 KB (1,944 words) - 06:57, 24 March 2013
- The '''Manage Raw Channels''' window is truly a powerful tool. In this document, we will explore some of the more advanced There are a number of columns in the Raw Channel window. Figure 3-10 shows a subset of those columns. (Some columns are out of view.) ...13 KB (2,084 words) - 04:26, 20 October 2013
- <big>This is a copy of the HOWTO on [http://www.computerchristmas.com ComputerChristmas.co ...er nail polish and a toothpick to touch up ANY place that I think MIGHT be a problem. Looking over the PCB and touching it up takes me 5 to 10 minutes, ...11 KB (2,059 words) - 04:41, 29 January 2011
- ...s that were animated to music and thought that you would also like to make a similar display. ...first results were probably the commercially available systems and you got a case of “sticker shock” when you saw how much it was going to cost to make ...13 KB (2,155 words) - 23:52, 28 January 2011
- ...standard disclaimers pertaining to the information contained on this wiki page are listed [[Disclaimers | here.]]<br/> ...in digital signs, pushed in from the back of the faceplate of the sign, in a pretty closely spaced grid. So, they are relatively waterproof, as in desig ...11 KB (1,690 words) - 01:39, 7 February 2015
- ...ircuit takes an audio source such as an MP3 player and outputs a signal to a hobby servo to move the jaw to the sound on talking props. ...maximum servo position when sound is present. You can think of this like a high limit switch ...17 KB (2,930 words) - 21:01, 15 August 2012
- ...ool designed by IdunBenhad for the DIY community. The bridge combined with a DVM or Ammeter will allow the user to "match" the antenna and other environ ...ink of it in terms of water flow. That is, if you put a one inch faucet on a two inch pipe, your potential output will be restricted by the one inch out ...24 KB (4,238 words) - 01:55, 22 February 2016
